Classic 2CV Racing Club Ltd Forum => Technical => Topic started by: Jose M Oliva on May 21, 2009, 12:00:46
Title: Looking for some carburettor advice
Post by: Jose M Oliva on May 21, 2009, 12:00:46
Hello.
I have two Solex 26/35 CSIC carburettors, one installed on car and another one that I have never tested. These are their characteristics:
Installed one (corresponds to a very late model, therefore a bit of mpg conscious):
Primary venturi bore: 18 mm
Secondary venturi: 26 mm
Primary main jet: 102
Secondary main jet: 90
Idle jet: 39
Primary air correction jet: 1F2
Secondary air correction jet: 2AA
Pump injector: 1 (¿35?)
The one I have never tried:
Primary venturi bore: 21 mm
Secondary venturi: 24 mm
Primary main jet: 120
Secondary main jet: 70
Idle jet: 40
Pump injector: 40
My engine has the biggest compression ratio allowed by Tech Regulations and also the Club camshaft. Currently I am using the carburettor standard settings, but I believe there is some improvement available on this matter. My first idea is to switch to the second carburettor as it has more air pass, but I do not know what to do with the jets.
Does anybody have any advice about this topic that can be shared?
Thanks in advance and best regards,
José M. Oliva
Title: Re: Looking for some carburettor advice
Post by: Paul Robertson on May 21, 2009, 13:43:36
Drill out primary fuel 102 to 135,secondary fuel to 95,1f2 to 130,2aa to somewhere between 130 and 160.this is the same regardless of which carb you use although i would tend to use the 21/24
Post by: Dennis List on June 04, 2009, 21:13:02
I kind of got the same setup in my road 2cv. 9:1 compression and camshaft done by Kent Cams to be almost identical to the Club one.
I recently installed a 21/24 carb as well (came from a Dyane) after getting this tip from the Dutch racing team. I currently have 120 primary and 120 secondary jet and thought this may well be a little too much. But reading Paul's reply i understand we can go even bigger with the jets.
Do you also use an open airfilter (instead of the stock one?). I do, and that means a lot more air can be sucked through.
Post by: Steve Panas on June 05, 2009, 11:33:05
open air filter gives too much noise on day to day basis ::)
