Classic 2CV Racing Club Ltd Forum => Technical => Topic started by: Onashoestring2cvracing on March 14, 2026, 22:52:33
Title: helmet
Post by: Onashoestring2cvracing on March 14, 2026, 22:52:33
hi all im looking at buying a helmet and ive read the the 2026 bluebook and found a load of numbers for helmets but anjust wondering before i comit to buy the helmet if i post the link if someone is able to tell me if it eligible to use thanks pete annells
https://zamphelmets.eu/product/rz-57v-matte-gray/#description
Title: Re: helmet
Post by: Matthew Hollis on March 15, 2026, 09:07:17
Hi Pete, yes it is valid, the rating is Snell SA2025, assuming you are happy with it.https://ebooks.motorsportuk.org/najd/p355 (https://ebooks.motorsportuk.org/najd/p355)
Note that you will need to buy HANS posts separately https://zamphelmets.eu/product/hans-posts/#description (https://zamphelmets.eu/product/hans-posts/#description) and also a HANS device (technically called FHR device in the regs) if you don't already have one e.g. https://www.gprdirect.com/helmets/head-neck-safety-hans/fhr-hans-devices/page/1/ (https://www.gprdirect.com/helmets/head-neck-safety-hans/fhr-hans-devices/page/1/)
Title: Re: helmet
Post by: Onashoestring2cvracing on March 15, 2026, 20:56:57
hi Matthew thanks for the reply ill look into getting it
Title: Re: helmet
Post by: Andrew Bull on March 20, 2026, 08:20:43
Pete.
Zamp are a very up to date helmet manufacturer and are used by myself and a large number of other driver in 2cv.
Smell 2025 is the latest spec and at present has no expiry date so will
Be valid for a good number of years.  Ten if imagine.
Do t forget the HANs Posts and if possible buy a helmet with them
Pre-fitted.
Zamp sizing is quite accurate and fit is very comfortable but snug.
HANS device will be required.  If you buy second hand then the only item that is dated is the tether strap which can be bought separately.
Take care with your overalls as any printing (if done) embroidery and stitching must be by the manufacturer and use appropriate fabric and threads.  The worst case is confiscation at the scrutineering.
Overall must have stitched in to the collar the FIA standard.  Found in cghapter 9. https://ebooks.motorsportuk.org/najd/p353
Title: Re: helmet
Post by: Howard Wright on March 20, 2026, 21:09:32
Whatever helmet you choose, I recommend going to a store where you can try it on. I intended to buy a particular Bell helmet as it was at a good price. Happily, I went into my local dealer, Alex Reade at Brands Hatch, where I discovered Bell helmets don't fit my shape of head. When I tried an Arai, it fitted my head nice and snugly.
