Marc,
Please contact me regarding the parts I left with you last year. I have tried texting you to get either some form of payment or get the parts back but with no result. You promise to do something but nothing has happened each time!!
There are quite a few high value parts in the job lot I left with you and to be honest I just want it ALL back now. I'll sell it to someone else that will pay!! I need the money!!
My number is 07901 716902 and you know where I live.
And if anyone wants a shell (new floor & sills) and Safety Dynamics roll cage (not up to current spec but very good), rear axle & arms, gearbox, driveshafts, wheels, doors, engines, pistons, barrels, brakes & heat sinks, dianne carb, inlet manifold, exhaust manifolds with lambda sensors, Magnecor plug leads, 5kg seat, Williams 6 point 3" harness, Leda dampers (need rebuilding) turned front arms, std spring cans, solid track rod end couplings, exhaust heat wrap,std instruments, brake pads, brake fluid, front spoiler, front screen, 30 Varley red top battery, slave bettery connectors, FAI master switch, stainless flexible exhaust tubing, catch tank, lights, bonnet...... etc please call/mail
Steve
Money and parts are on there way. I ahve them here now for you. Have done for ages.
I not been around here at the moment as moving away. Sorry for delay.
Will try get them over this week.
Hi Steve
Do you have a detailed pricelist. I m ight be interested in a few bits.
Thanks.
Kris
Steve,
Same here. Can you drop me a mail on
[email protected]?
Ben
