Weber carb air leaks.
Started by Martin Sadler, December 21, 2011, 23:00:42
Martin Sadler
I have been trying to acheive an effective leaf free mounting of the carb to manifold joint. It all started with one Keith Shoebridges engines at Snet that we didnt effectively cure. I've just started on my engines and its even worse! The adapter plate fits in such a way that there is almost 1mm of gap over the counter sunk screw head - thats an awful lot a lot of gasket goo. The leak is so bad the engine barley runs. Is that the correct way of fitting? Also the adapter plate shrouds the carb throughts badly. I presume we just flow them into the manifold? Any body got any ideas?
Use polyurethane mastic Martin ,or make your own as this years rules will allow.
Where can we all view this years rules and regs Paul?
I did ask phil if he could post the changes alec. They are usually on the barc website once approved.
as soon as I have the official copy I'll post them on forum.
