master kill switch
Started by naughtybear, September 15, 2013, 20:05:09
Hi Guys can anyone help?
I wired up the mains battery isolator today only to turn the power on and get nothing to terminals '2' on the underside of the switch, has anyone else experienced this?
Ash
Hi Ash attached wiring diagram hope it helps, and Happy Birthday for the other day.
thanks for diagram and birthday wishes, I have checked the image and I have appeared to have wired up as per instruction but when I turn master switch on I don't appear to get power to terminals '2' i.e ignition and coil but have power to the car side of the switch - I am thinking duff switch but not sure unless I have to earth the resistor but don't see what bearing this would have when I am at this point testing the panel before I go much further.
rr Ash
Sammie Fritchley
It's just an on/off switch Ash,it doesn't transfer power from the main terminals.
ok so it might have been operator error , thanks guys
