2CVParts.com Championship standings (after Cadwell Park)
Started by Matthew Hollis, May 28, 2015, 13:00:00
0 Members and 3 Guests are viewing this topic.
RLambert
The fact is that the rules are crap but rules are rules and they are not being applied correctly.
I've written to Ian Watson to try and see if we can come up with a solution.
If it stays as it is I'm going to have to reconsider if it's worth doing the 24hr race.
steve walford
After reading this I still struggle to understand how you can not be scored the points for the races that you enter ?? however the points system is worked then I still think that you should score the points that you achieve in the races that you race in regardless of which car you are in
if the rules are rules and need to be applied exactly as written then Pete should be awarded the 316 points that the two cars earned at Cadwell. as it is I think that common sense has been used and the points are correct.
This would have to be applied to Mick Storey too then  ;D
Don't give mick more points I'm enjoying being in front of him :)
Does that mean that he doesn't like being behind you????  :-\
