Lean in long corners.
Started by gasklep, August 04, 2016, 21:40:45
0 Members and 4 Guests are viewing this topic.
The large pipe that vents into the second choke,we used to remove it and fill in the hole .
gasklep
Quote from: Paul on August 21, 2016, 20:45:52
And run without air vent? Can you remove it without side effects? Or do you have to make a alternative vent?
gasklep
Quote from: gasklep on August 21, 2016, 21:20:49
Anyone?
#18
No alternative vent,if you remove the choke flap and spindle and carefully blank off the outsides,the float chamber is vented via the holes in the primary choke.
