AGM Agenda and Proposals
Started by Dick Roberts (Web admin), December 03, 2004, 12:10:08
Posted by Trevor Williams on October 14, 2004 at 16:39:56:
Please note: this is the draft agenda and list of proposals. This needs to be checked with Paul Taylor, and if any amendments are required they will be posted before the meeting
2CV Racing Club
Annual General Meeting
24th October 2004
Agenda
1. Apologies For Absence
2. Introduction and Chairman's Report
Sprint Championship
Enduro Championship
24 Hour Race
3. Treasurer's Report
4. Election Of Club Officers
Chairman: No Change
Secretary: Christine Thompson
Proposed by Christine Thompson, seconded by Sammie Fritchley
Treasurer: No Change
Technical Committee: No Change
Snails Pace
R Hollis and M Hollis to stand for editor for Snail Pace Club Magazine
Proposed R Hollis, Seconded M Hollis
5. The Year 2005
Race Meetings: 5 Weekends comprising a sprint and endurance race at each meeting, subject to BARC agreement. Snetterton to be a stand-alone Non-Championship Race.
Proposed by Trevor Williams, seconded by Pete Sparrow
A Club Car, paid for and maintained by club members available for "guest drivers". Appointed (volunteer) club member responsible for getting drivers, competition insurance etc. BARC / 2CVRC / AVO / Members to sponsor the car.
Proposed by Pete Sparrow, seconded by Trevor Williams
6. Constitutional Matters
7. Sporting Regulations
8. Technical Regulations
9. Membership Items
Race Numbers
Racing Membership Fees
Day Membership Fees
Associate Membership Fees
Website
10. Technical Committee Recommendations
11. Championship Sponsorship
Associate Sponsorship
24 Hour Race Sponsorship
12. AOB
Sporting Regulations:
Success Ballast to be adopted by the Club.
Proposed by Trevor Williams; Seconded by Pete Sparrow
Driver Change Enduro: Change for single drivers to Get Out / Close Door / Open Door / Get In
Points Scoring: go from present system to 20 for win, 19 for second down to 6 for 15th, all other classified get 5 points. Pole = +2, fastest lap = +1.
No Drop Round in Championship Points total if we go to a five round championship.
Bonus points for doing all the rounds of the championship if we go to a five round championship.
No Bonus points for Snetterton Entry.
Start Money to be paid out of Club Funds to every driver who starts a Championship Race in sprint races, and every car owner in enduro races to subsidise the cost of entries if we go to a five round championship. Not including Snetterton
Reverse grid starts and qualifying points
Qualifying times are awarded points that count towards the championship, (to be decided, e.g. 10 points = pole, 9 = 2nd etc. down to 1 = 10th and all other position back). The qualifying times do not equal the grid starting positions. These are calculated from the championship positions, (bar the 1st round where they are drawn from a hat or last years championship order), and the entries with start in reverse championship order. Drivers have the option to start from the back if they declare so prior to qualifying.
New rule be added. The wording to read 'The 24 Hour race organising group to be given the freedom to make reasonable minor changes to the technical and sporting regulations, if in their view, such changes will help maximise the number of cars starting the 24hr race'.
Proposed by Martin Harrold, seconded by Roy Eastwood
New rule to be inserted: 'The Technical Committee to review the possibility of a weight handicap system being introduced. Trials to be carried out. Once a considered proposal has been prepared, then an e-mail vote is to be taken, only to be actioned if 75% + of the paid-up members vote and 66% of those voting are be in favour'.
Technical Regulations:
Approved By The Technical Committee:
Not Approved By The Technical Committee
No changes to tech regs for 2005 as a period of stability
Proposed by Paul Robertson, seconded by Phil Myatt
Any proposals for tech change at this AGM should be investigated fully by the tech committee with appropriate funds allocated to make this possible before being adopted (or not) for the 2006 season
The tech committee to investigate the possible use of an alternative carburettor that is readily available new and cheap for adoption into the 2006 regs (or not)
Use only 18/26 Carb, ban 21/24 carbs. All other permitted carb mods to stay the same.
Tyres: Allow the use of Smart Car tyres of sizes 135/65/R15 and 145/65/R15 – only if a manufacturer is listed by the MSA for motorsport use.
Mandatory use of Standard heads sourced from ECAS and "worked" by one company at a set and agreed cost.
Mandatory use of a Standard exhaust system available at a set cost (2-into-1)
Mandatory use of Standard Air filter (big Green) at set cost from approved supplier
Mandatory use of Standard Carb at set cost from approved supplier. Tech Committee to recommend replacement carb and supplier.
Mandatory use of standard jets at set cost from approved supplier
Club to specify cam timing.
Proposed by Pete Sparrow Trevor Williams; Seconded by Trevor Williams
Standardisation of shock absorbers
Competitors will use any standard Citroen A-Series shock absorber (Ami inc. Super, 2CV, Dyane, A-Series van) or AVO adjustable shock absorbers only. Modification for the fitting of a nipple to vary the oil type held within the shock absorber is permissible on the Citroen A-Series shock absorber.
Use of Club Camshaft and Citroen Camshaft
Technical rules on engines remain unchanged in all aspects for 2005 except for the supplementary regulation as follows. Any engine will deemed legal and accepted to race with a standard Citroen Camshaft fitted (under the rules of 2003), however the vehicle using this camshaft must conform to and have fitted the following parts: (should the technical committee deem it appropriate and necessary).
-125/15 tyres fitted all round
-standard early or late type flywheel with no machining
-standard 2CV6 or Dyane airbox with standard manufacture recommended filter present in it correct placement.
-all fan blades fitted as standard
-a standard 2CV crossbox, interconnecting pipe and torpedo silencer and short exit pipe (from Merhari/Akvan) unmodified of the correct diameter and in their original manufactured positions.
Change the regulations on cams to read 'Cams are free'
Change the regulation on cams to read 'The cam grinding is free. The origin of the cam as a Citroen 2CV part to be clear and obvious. No vernier allowed'.
To change the regulation on cams to read: ' The cam grinding is free. The origin of the cam as a Citroen 2CV part to be clear and obvious. Vernier allowed'
Proposed by Martin Harrold, seconded by Roy Eastwood.
New regulation to be inserted: Cylinder head capacity is free. Cylinder barrel height is free'
