Handbrake
Started by Marc Fenner, February 01, 2010, 22:56:17
What floor mounted handbrake do people use? Is it a BX handbrake? Anyone got a spare one?
It is marc,i thought i had a spare but it's not where it should be. Sammie
Martin Sadler
Hi, I'm fitting a bx handbrake to my car, what cables do you use? or do they have to be made to fit?
Thanks.
We use a modified bx one that operates the standard underbonnet upright mounted to the chassis.
BX lever with the cable bit removed, clevis/rod/clevis through a hole in the bulkhead to the original underbonnet lever and standard cables.
I think Pete Sparrow had a contact who could modify cables; he needed a pair of BX cables and a pair of 2CV ones to do it with.
Martin Sadler
Thanks all, i'll first look at the rod arrangement and if unsuitable then i'll look at the cable (more costly) fittings.
