Interchangeable gearboxes?
Started by neandethal, June 06, 2022, 15:45:02
Hi,
With the disc braked gearboxes there are 2 styles of input shaft from the clutch, different spline arrangement.
Can either type be fitted to the same engine or do they have to be a matched pair? Thanks, Ian
They both work Ian, short spline with later clutch is not ideal but does function.
Many thanks, a get out of jail fix. Cheers
Roy Eastwood
the ratios must still be 2cv6 though, most short spline gearboxes are either Dyane Ratio or are equipped for drum type brakes
