upgraded spring tubes
Started by neandethal, March 17, 2013, 19:34:24
looks like the springs in ours have failed does anybody have an upgraded race spec spring tube assembly for sale, obviously i need both sides cheers, ian.
Nigel Hollis
Why not just fit new springs in your cans? I think ecas still list 170% uprated springs or Springcoil Ltd in Sheffield 01142731111 ( ask for Carl) will make what ever you want. We have found it advisable not to deviate to much in length so that the original tie-rods can be used without cutting - beware the front & rear are different lengths. Also the front of the can is stamped AV.
just to update everyone as i know it can be annoying when a thread doesnt complete.
inside our spring tubes we found that there were 2 springs welded together, one i now know as a diablo spring of good tension and one very weak spring. we have now welded the weak spring up as a solid spacer and reset the ride height, and guess what a fantastic solid ride and good damping.
Many thanks to Paul for all his help in guiding us through the process and solving our issue - top man.
